Forums
Architecture, Engineering & Construction Community Hub
Back
Architecture, Engineering & Construction Hub
See all
Product Design & Manufacturing Community Hub
Back
Product Design & Manufacturing Hub
See all
Media & Entertainment Community Hub
Back
Media & Entertainment Hub
See all
Community Hub
Back
Community Hub
See all
Subscription, Installation & Licensing
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Forums
See all
See all
See all
Community Hub
Community Hub
See all
All Forums
Blog
Events
Groups
Gallery
Autodesk University
Home
AutoCAD LT Forum
All community
This section
This board
Knowledge base
Users
Products
Turn on suggestions
Show
only
Search instead for
AutoCAD LT Forum
Welcome to the Autodesk AutoCAD LT Forum. Ask questions, share your knowledge, and make connections.
Autodesk for small business
Design & Make software that works as hard as your business.
Explore today
Activity feed
Communities by language
Ask a question, share your knowledge, or submit a product idea.
Start a topic
Options
Mark all as New
Mark all as Read
Float this item to the top
Subscribe
Bookmark
Subscribe to RSS Feed
Sort by Topic Start Date
All
Trending
Accepted solutions
Unanswered
Most Viewed
Latest
Oldest
New to the AutoCAD LT Forum?
Start Here
Community managers
CGBenner
Related tags
"2D Drawing"
(1)
"AutoCAD 2025"
(1)
"AutoCAD 2026"
(1)
"AutoCAD LT 2023"
(2)
"AUTOCAD LT 2026"
(1)
"dynamic block"
(1)
"Freeze"
(1)
"Graphics"
(1)
"Hatch"
(2)
"LAYERS"
(1)
"NLS Error"
(1)
"NUMBERING"
(1)
"PDF"
(2)
"Plotting"
(1)
*.LAS not importing colour states or descriptions .
(1)
-BLOCK
(1)
(1)
.csv
(1)
.dxf
(2)
.import
(1)
.lin files
(1)
.PAT files
(2)
.pdf
(3)
2013
(1)
2018
(1)
2021
(1)
2022
(1)
2022 version
(1)
2023
(1)
2023 AutoCAD LT
(4)
2D
(1)
2d Adaptive Help
(1)
3d
(1)
3D block to 2D line drawing
(1)
3D Editing
(1)
3DConnexion spacemouse
(1)
3dmodel
(1)
ACAD 2021
(1)
ACAD LT
(1)
ACADLT
(1)
action
(1)
actions
(1)
Activity Insights
(1)
Adding "+" prefix to formula in fields automatically
(1)
Annoatative Scales
(1)
annotated text not centered
(1)
Annotation
(3)
annotation scale
(1)
ANNOTATIVE DIMENSIONING
(1)
Annotative Scale
(1)
Annotative Text
(1)
Annotative Text - Justified Bottom Center - Text Space From Base Point
(1)
APPLOAD
(1)
arc text
(1)
architectural
(1)
Architecture
(1)
arctext
(1)
area
(2)
array
(2)
arrow
(1)
As Built
(1)
ASME
(1)
assistance
(2)
Attach Xref layer
(1)
ATTEXT
(2)
attribute
(3)
Attribute Block
(1)
Attribute Data
(1)
Attribute Editor
(1)
attributes
(3)
AudioVisual
(1)
auditorium
(1)
AuotCAD LT
(1)
Auto CAD
(1)
auto cad lt attext
(1)
auto generate
(1)
autocad
(19)
AutoCAD .NET
(1)
AutoCAD 2015LT
(1)
AutoCAD 2018
(2)
AutoCAD 2019Lt
(4)
Autocad 2020
(1)
autocad 2021
(3)
autocad 2021 lt
(1)
AutoCAD 2022
(2)
AutoCAD 2022 issues
(1)
AUTOCAD 2025LT
(1)
AutoCAD and OneDrive troubleshooting
(1)
AutoCAD Blocks
(2)
AutoCAD Certification Exam
(1)
AutoCAD Civil 3D
(1)
Autocad Dimensions Paper Space
(1)
autocad fatal error
(1)
Autocad help
(1)
AutoCAD LT
(34)
AutoCAD LT 2000
(1)
AutoCAD LT 2016
(1)
AutoCAD LT 2018
(1)
AutoCAD LT 2019
(7)
autoCad lT 2020
(5)
AutoCAD LT 2021
(29)
AutoCAD LT 2021 hangs
(2)
AutoCad LT 2022
(9)
AutoCAD LT 20224
(1)
AutoCAD lt 2023
(3)
autocad lt 2024
(3)
autoCAD LT 2024 printer plotter default
(1)
AutoCAD LT 2026.0.1
(1)
AutoCAD LT Diesel getvar
(1)
AutoCAD LT Errors
(3)
Autocad LT File Tabs
(1)
AutoCAD LT Forum
(1)
AutoCAD LT Installation file size
(1)
AutoCAD LT lagging
(1)
Autocad LT LISP problem
(1)
AutoCad LT Version 2022
(1)
Autocad Lt Xref
(5)
AutoCAD ObjectArx
(1)
AutoCAD Text Appearance
(1)
AutoCAD Titleblocks
(1)
Autocad vectorworks
(2)
autocad2012LT
(1)
AutoCadLT
(5)
Autodesk 2014 LT
(1)
Autodesk CALS Tools 2011
(1)
Autodesk Certification
(1)
Autodesk LT
(1)
Autodesk University
(1)
Autofill
(1)
autohotkey
(1)
autolip
(1)
Autolisp
(1)
AutoLISP and General Customization
(1)
automatic
(1)
Automation
(1)
BALLOONING DRAFT
(1)
Basepoints
(1)
batting
(1)
battman attsync
(1)
Beginners
(1)
Best Practice
(1)
Bind command
(1)
block
(8)
Block Attributes
(2)
block edit
(1)
block editor
(2)
Block Explode
(1)
block help
(1)
Block Insert
(1)
Block Libraries
(1)
Block Properties Table
(1)
Block references
(1)
block rename
(1)
Blockreplace
(1)
blocks
(7)
Blocks - Dynamic Blocks
(1)
Blocks Library
(1)
Book
(1)
Broken Hatched Text during PDF Import in AutoCAD
(1)
bug
(1)
but i need polylines.
(1)
Button
(1)
CAD 3D
(1)
Cad Freeze
(1)
CAD help
(1)
Cad Lt
(2)
Can't open file
(1)
Ceiling Grid
(1)
Centres of the circles
(1)
Certification
(1)
CERTIFICATIONS
(1)
Chain
(1)
chained
(1)
chairs
(1)
changes
(1)
circle
(1)
Civil 3D object enabler
(1)
Close
(1)
Cloud
(1)
Color
(1)
Color Book
(1)
Colorbook
(1)
colors
(1)
colour
(2)
colour management
(1)
command
(2)
Command Error
(1)
command line
(1)
Command Line Issues
(1)
Command problem
(2)
COMMAND STRING
(1)
command's
(1)
Commands
(4)
Compatibility
(1)
conference
(1)
config DWG icons
(1)
Constraints & Parametrics
(1)
Construction
(1)
Contours
(1)
converting
(1)
coordinates
(2)
Copy
(2)
copy and paste
(1)
Copy Command
(2)
copy drawing
(1)
copy paste
(1)
copy paste issue
(1)
copy-paste viewports
(1)
CopyClip
(1)
copying between designs
(1)
COUNT TEXT
(1)
Counter
(1)
crash
(1)
CSV
(1)
CSV import
(3)
CUI
(2)
CUIX
(1)
Cursor
(1)
curve
(1)
curved text
(1)
curving a hatch
(1)
CUSTOM HATCH
(1)
Custom Hatches
(1)
Custom Linetype
(2)
Custom menu
(1)
Custom Properties
(1)
custom shape
(1)
Custom table
(1)
cut list creation
(1)
CutePDF
(1)
DASHED SPLINED PLINE
(1)
Data Extraction
(1)
Data extraction in AutoCAD LT
(1)
Data Link
(1)
datalink
(2)
Decimal
(1)
Default Changes
(1)
Default Value
(1)
Dell
(1)
DesignCentre missing
(1)
Dialogue box
(1)
Diesel
(2)
Digitizers
(1)
dim
(1)
dimaligned to dimlinear
(1)
dimension
(4)
dimension help
(1)
dimension issue
(1)
Dimension Units
(1)
Dimensional Question
(1)
Dimensioning
(3)
dimensions
(8)
dimordinate + ucs
(1)
DIMSCALE
(1)
DIMSTYLE
(1)
dimstyle settings
(1)
diplay-error
(1)
Discover
(1)
Display
(3)
display issue
(1)
Display Issues
(1)
Dogleg
(1)
double-click
(1)
Drafting
(2)
Drafting Accuracy Errors
(1)
draw order
(2)
drawing
(2)
Drawing coordinates
(1)
Drawing History
(1)
drawing lines
(1)
Drawing title block default font size
(1)
DRAWING UNITS
(1)
Drawing View
(1)
Drawings
(1)
dwf
(1)
DWFx
(1)
dwg
(2)
DWG file association
(1)
dwg file information
(1)
DWG to PDF
(2)
dwg version
(1)
dxf
(2)
dynamic block
(8)
dynamic blocks
(3)
Editing Items
(1)
ELECTRICAL DRAWINGS
(1)
elevation
(1)
embedded drawings in Word
(1)
equally
(1)
Error
(2)
Error message
(1)
ERRORE IRREVERSIBILE
(1)
errors
(1)
etransmit
(1)
Event
(1)
Excel
(1)
Excel to AutoCAD
(1)
explode
(1)
explode text
(1)
Export DWG to PDF
(1)
export layouts
(1)
export PDF
(1)
external reference
(1)
External references
(2)
Fabrication
(2)
facility management
(1)
Family Linetypes
(1)
faster feet and inch input Autocad LT
(1)
fatal error
(3)
Fatal Error 0x7ff9799b0005
(1)
FATAL ERROR: (0x7fffeac10005)
(1)
FATAL ERROR: Unhandled Access Violation Reading
(1)
Feature error
(1)
FIELD
(3)
field variable
(1)
fielddisplay
(1)
Fields
(2)
File Management
(2)
file name
(2)
file naming
(1)
file path
(1)
File References
(1)
file share
(1)
filename
(1)
Files
(1)
fillet not working
(1)
Filters
(1)
flickering
(1)
flickering issues
(1)
Font
(1)
font color
(1)
Font Display
(1)
formatting
(1)
Formula
(1)
freeze
(1)
geolocation
(1)
georeference
(1)
GIS
(1)
GIS Maps
(1)
glitch
(1)
GPS
(1)
GPU for AutoCAD-LT
(1)
graphic issue
(1)
graphics
(1)
Graphics & Visualization
(1)
Graphics card supporting AutoCAD LT 2022
(1)
Graphics Hardware issue
(2)
grid
(2)
Grip points
(1)
Groups
(1)
Hachure sur XREF
(1)
hardware
(2)
Hardware acceleration
(2)
hardware accelerator
(1)
Hatch
(10)
Hatch export
(1)
hatch pattern
(1)
Hatch Patterns
(2)
hatch problem
(1)
Hatch problems
(1)
HATCH SETTINGS
(1)
Hatches
(1)
Hatching
(1)
Heat Pump UK Plant Schematic Blocks
(1)
Help
(8)
Help & Support
(3)
HELP PLEASE!
(1)
Help required
(1)
Hidden block
(1)
hidden blocks
(1)
High DPI
(1)
highlight
(1)
highlighting
(1)
hotfix
(1)
How to
(1)
Hyperlinks
(1)
i9
(1)
Icon
(1)
IF-THEN
(1)
(1)
Image services (.wms)
(1)
imperial arrow
(1)
Import
(3)
Import and Export
(1)
Import data
(1)
Improvement
(1)
Industry Communities
(1)
Insert
(3)
insert publish
(1)
Installation
(1)
Insulation
(1)
INTEL
(1)
invisible
(1)
invisible at startup
(1)
invisible elements
(1)
Issue
(4)
Issues with AutoCAD
(1)
jagged
(1)
jog
(1)
join
(1)
joining arcs and polylines undesirably creates splines
(1)
KEYBOARD SHORCUTS
(2)
lag
(1)
Landscape
(1)
Laptop Spec
(1)
Latitude5330
(1)
Launch problem
(1)
Layer
(2)
Layer issues
(1)
Layer Manager
(1)
layer properties
(1)
Layers
(5)
LAYOFF
(1)
Layout
(3)
Layout Tools
(1)
Layouts
(1)
leader
(1)
LEADER edit
(1)
Leader Lines
(1)
Leader manipulation
(1)
Leader settings
(1)
legends
(1)
lenght
(1)
Line
(1)
Line Join Style
(1)
Line type
(1)
Line value
(1)
lines
(3)
Linestyles
(1)
Linetype
(3)
linetype creation
(1)
linetype generation
(2)
linetype scale
(3)
linetype weight
(1)
Linetypes
(6)
Lineweight
(1)
LineWeight Printing
(1)
Lisp routine
(1)
lisp routines
(1)
list
(1)
load application
(1)
location PDF Images folder
(1)
LSP-files
(1)
LT
(8)
LT2025
(1)
Macro
(5)
Macro Help
(1)
Macros
(4)
Make Current
(1)
Makro (CUI)
(1)
Manufacturing
(1)
mapiinsert
(1)
Maps
(1)
material list
(1)
measurements
(1)
Mechanical
(1)
Mechanical Settings
(1)
medical
(1)
menu
(2)
message
(1)
messt text
(1)
Migrating files
(1)
MLeader
(1)
mleaderalign
(1)
MLEADERSCALE
(1)
MNS
(1)
model tab
(1)
mtext
(2)
MTEXT not responding
(1)
mtext wrapping
(1)
Need help to install
(1)
New Feature
(1)
new layer notification
(1)
New TO AutoCAD
(1)
Not working
(1)
notvisible
(1)
Object Enaber
(1)
Offset
(1)
ole
(1)
OneDrive
(2)
ordinate
(1)
OSNAP
(3)
osnap mode
(1)
OSNAPS
(1)
outlines
(1)
Palettes
(1)
pallets
(1)
paperspace
(2)
Parameters
(1)
Parts
(1)
Paste
(2)
paste command
(1)
pasteclip
(1)
PASTESPEC
(2)
PCU
(1)
PDF
(8)
PDF convert
(2)
PDF export issue
(2)
PDF Import
(3)
PDF issue
(1)
PDF Issues
(3)
pdf watermarks
(1)
PDFs
(1)
Performance
(1)
Photos
(1)
PICKDRAG Lasso issues
(1)
PICKETS
(1)
PICKFIRST system variable
(1)
(1)
pictures
(1)
PLINE segment removal
(1)
plot
(6)
Plot and Publish
(1)
plot date
(1)
plot preview
(1)
plot problem
(2)
plot styles
(1)
Plot to PDF
(3)
Plot to pdf issue
(2)
plotted
(1)
Plotter
(1)
Plotter paper sizes
(2)
Plotting
(9)
Plotting issues
(7)
Plotting stb ctb
(1)
Points
(1)
polar tracking
(1)
Poly line
(1)
polyline
(4)
polyline closed wipeout line segments
(1)
Polyline Edit
(2)
Polyline Plot Width
(1)
polylines
(2)
Precision
(2)
preserve text
(1)
print
(3)
Print points
(1)
Print to PDF
(2)
PRINTER
(4)
printing
(4)
Printing issues
(2)
problem
(1)
Processor
(1)
Product Forums
(1)
Product Updates
(2)
Production
(1)
properties pallete
(1)
proxy
(1)
proxy entity
(1)
proxy text
(1)
PSPACE
(1)
Publish
(4)
Publishing issues
(2)
purge
(4)
python
(1)
QGIS
(1)
qnew
(1)
qselect
(1)
Quck access toolbar
(1)
Question
(2)
Quick Access
(1)
quick access toolbar
(1)
Read only
(1)
Recording
(1)
Rectangle
(1)
regen terminated
(1)
Regionen
(1)
Request for Apps
(1)
Revision
(1)
Revision Clouds
(1)
Revision Control
(1)
Revit
(1)
Ribbon
(1)
S-DIM
(1)
save error
(1)
scale
(3)
Scale Bar
(1)
scale box
(1)
scale co-ordinates
(1)
scaling viewports
(1)
Schedule
(1)
Schriftfeld
(1)
Screen lower half dark
(1)
Scrip
(1)
script
(1)
Scripting
(1)
scripts
(1)
scrolling
(1)
Search
(1)
seating
(1)
seating plan
(1)
Security
(1)
Selection Highlight
(1)
Selection preview
(1)
selection window
(1)
Settings
(2)
Setup
(1)
shaft
(1)
sharepoint
(2)
Sheet Manager
(1)
sheet set fields
(1)
sheet set manager
(2)
Sheet Set Properties
(1)
Shift key Toggle
(1)
slow
(1)
Slow Performance
(1)
Snap
(1)
Snap Settings
(1)
Snapping
(1)
Snapping with AutoCAD LT 2023
(1)
Software
(1)
software help
(1)
Solar Analysis
(1)
solid white
(1)
SolidWorks
(2)
Spellcheck
(1)
Spherical Slicing
(1)
spline
(2)
splines
(2)
ssm
(1)
Standards
(1)
startup
(1)
startup page housekeeping
(1)
Startup problem
(1)
Startup Switches
(1)
steel structures
(1)
stretch
(2)
stretch action
(1)
Suddenly Crashes
(1)
Suggestions
(1)
Support
(1)
Survey point
(2)
Switch
(1)
synchronization
(1)
synchronize
(1)
T-grid
(1)
table
(1)
table cells background mask
(1)
Table Glitch
(1)
Tables
(3)
Tablet
(1)
Technical Issues
(1)
Template
(2)
template file
(1)
Templates
(2)
temporary override
(1)
text
(8)
Text and Mulitleaders
(1)
text box
(1)
text not centered
(1)
text not saving
(1)
TEXT STYLE ERRORS
(1)
Text Styles for Enhance Attribute Editor
(1)
Text wrap
(1)
Texts
(1)
Textstyle
(1)
theatre
(1)
thickness
(1)
title block
(1)
Tool Palette
(1)
Toolbar
(1)
toolbars
(1)
Topo
(1)
Touchpad problem
(1)
Track pad
(1)
Trackpad problem
(1)
Transparency
(2)
troubleshooting
(10)
True Color
(1)
True Colour
(1)
UI
(1)
Undo
(1)
UNDO Command
(1)
Unhanded error
(1)
units
(4)
update
(1)
Update-Service Packs
(1)
Updates
(1)
Upgrading
(1)
User experience
(1)
User Settings
(1)
Utility Settings
(1)
variable
(1)
Variables
(2)
VBA
(1)
Vertex
(1)
View
(1)
View ports
(1)
viewcube
(2)
viewing issues
(1)
viewport
(3)
Viewport Freeze
(1)
Viewport Lineweight
(1)
Viewports
(4)
Visibility states
(1)
Visual LISP
(1)
vport
(1)
WBLOCK
(1)
welcome
(1)
whipeout
(1)
WIPEOUT
(1)
wmf
(1)
word files
(1)
workspaces
(1)
x-ref
(1)
x-refs
(1)
Xclip
(1)
XCLIPFRAME
(1)
XLines not trimming
(1)
xref
(6)
xref image civil3d
(1)
Xref layer
(1)
XREF LT
(1)
xref manager
(1)
XREF Plotting
(1)
XrefIssues
(1)
xrefs
(3)
zoom
(2)
Zoom Extents
(1)
Zoom problem
(1)
Previous
Next
Event
[Webinar] Power Your Designs With the AutoCAD Mechanical Toolset
Oct 30, 2025
7:00 AM US/Pacific
See all events
Top contributors
User
Count
Akunkinga
1
h_s_walker
1
mary.mimnaugh
1
paullimapa
1
maaritVJZJG
1
View All
