Hello!
I have AutoCAD LT and a recently purchased Logitech MX Master Wireless Mouse. The mouse works great *except* in AutoCAD LT! When running AutoCAD, the pointer will freeze, disappear and moments later reappear elsewhere on the screen. I contacted Logitech and verified the mouse has the latest driver. Logitech stated that it is an AutoCAD problem. I do not have the problem with a wired mouse. Any ideas?
cmengineer2000
Dean,
Good point!
LT version is...N.301.0.0 AutoCAD LT 2017.1.1
Windows version is...Windows 10 Up to date as of 6/17/17
My video card is...NVIDIA GeForce GT 745 Driver Version 376.53
If you are using a modern LT version, you might have to turn off hardware acceleration.
i was having a similar issue when i discovered that it may be related to the chromium host executible files... i havent found the answer for those, but i have found that if i turn off my wifi, disconnecting from any internet sources... my mouse then works great. Note... it doesnt seem to be a constant problem, but turning off the wifi when the freezing happens will unfreeze the mouse... fyi.. im using a logitech also...
