Announcements
AutoCAD LT - Turn off Fillmode on selected hatches/layers
simongilbertTCXH6
Observer
simongilbertTCXH6
Observer
Observer
I receive architect's drawings with a lot of hatch fills for items like furniture, cars etc.
When preparing the drawing for our annotations (we annotate data outlets and AV requirements) I often go through layer by layer and turn off what I can, or physically delete the hatch fill. This often involves going into the block editor and messing around.
Is there a way I can strip the fill from the model entirely? I've tried fillmode - however when I then add our drawing template, all our icons are also missing their own hatch fill on the paper.
I like to remove all the hatch colour fills from the original drawing and turn all layers to black to remove any distractions from our annotation.
Unless there is a simpler way to achieve this?
Appreciate any help on this 🙂
Si
[ The subject line of this post has been edited to include the product name by @handjonathan ]
pendean
Community Legend
Community Legend
SELECTSIMILAR is a great built-in command to, well, select items that are similar like your hatches and fills.
Same with FILTER and QSELECT commands. Give those a try, then ERASE or move or whatever it is you need done after that.
LAYER and PROPERTIES command to do that second item "...turn all layers to black...".
HTH
simongilbertTCXH6
Observer
Observer
Thanks for the prompt response pendean.
I've played around with SELECTSIMILAR before, but it's not quite what I'm after. It's frustrating, FILL or FILLMODE does exactly what I need on the model, just not the desired outcome when I include our template.
I've attached a drawing I've recently received as an example. Some blocks, such as the MOT equipment does not allow me to edit their fill/hatch.
h_s_walker
All the hatching is on a layer called HATCH COLOUR - EXISTING. I just turned it off. And I can't edit those "blocks" either as they have somehow given them the internal AutoCAD naming convention for changes made to a dynamic block. See the image below
Howard Walker
Left Handed and Proud
pendean
Community Legend
Community Legend
As noted by others, your sample file is quite well organized by layer, took about a minute to find and freeze those layers to make all the hatching/fills go away. Any reason that is not an option?
There are a couple of errant hatches left, a quick move of them to one of those hatch layers fixed that. 30-seconds
Setting all LAYER colors to WHITE get you almost there: using PROPERTIES to set all objects to BYLAYER gets you closers. SETBYLAYER command's many options fixed your BLOCKs that do not conform to BYLAYER for color. 2-minutes.
Using SELECTSIMILAR command to isolate the two DIMSTYLEs with override colors for dimline and dimtext took care of those. 1-minute.
The only thing you cannot change from the outside in LT are these two MTEXT with color overrides inside the editors
I lost track since I was typing at the same time, but isn't that about 5-ish minutes to turn your outside DWG file to a no-color hidden-hatches/fill result you wanted? See attached.
Learning the program and getting very comfortable with it, aka the tool of your trade, comes in very handy: but it takes time to get there for sure. Invest in that time.  The billable rewards later are priceless.
HTH
handjonathan
Hi @simongilbertTCXH6
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @pendean & @h_s_walker helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
