AutoCAD LT running slow - is it my computer spec?
ralph09
Message 1 of 11
ralph09
I recently bought a new PC and currently using the AutoCAD LT trial my computer appears to be struggling, which surprised me!
As far as I can tell the specs are more than adequate compared to the minimum required. I'd like to know whether my PC is simply not good enough to run CAD smoothly, or if it suggests there might be a different problem.
Drawing a polyline, with dynamic input, polar tracking and object snap turned off it is smooth. However, with all of these on, there is a 0.5-1 second lag on every click - very painful to use!
Attached are my specs, let me know if you need more info.
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
Your LT version is....?
Your Windows version is....?
Is AutoCAD/LT using the Radeon Video card or something else?
Is your video card driver one from Autodesk (if there is one here) http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Message 3 of 11
Use "GRAPHICSCONFIG" command and turn off the "Hardware Acceleration"
Hope this will help.
Glen
Message 4 of 11
ralph09
Hi thanks for your quick reply. Sorry for my slow one - I thought I would get an email notification but didn't!
It's AutoCAD LT 2017 version N.52.0.0
Windows 10 64 bit
AutoCAD is using the Radeon RX 460 graphics card, driver version 21.19.525.258, DirectX 11.
I've tried hardware acceleration on and off, didn't notice a significant difference either way.
R
Message 5 of 11
ralph09
The video card isn't listed on Autodesks certified or recommended list.
If that means it doesn't run smoothly then that's the answer. I was just surprised by that - I thought that AutoCAD LT should still be able to run smoothly with my hardware, even if my graphics card isn't one of the ones for which they've gone through certification process.
Message 6 of 11
pendean
Community Legend
Community Legend
A few things to try:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cursor...
Turn off LINEFADING and LINESMOOTING variables in LT2017
If you have them selected, uncheck the boxes for MAINTAIN VISUAL FIDELITY and MAINTAIN DRAWING SIZE in OPTIONS command's OPEN&SAVE tab.
Ensure SAVE is set to the default 2013dwg file format for the trial period testing.
Ensure all files are 20123dwg file format for the trial period testing.
Did you by chance invoke any "migration" tool when you installed LT2017? that may contribute to the slowness.
Where do you store files that you access? Just curious, doubt is has much to do with it all but you never know.
Message 7 of 11
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Message 8 of 11
ralph09
Thanks for all the help and input.
I had a play with some of the settings, and now am unable to recreate the original problem, which means everything is now working smoothly! Not sure exactly what fixed it!
Kind regards
Ralph
Message 9 of 11
Looking at purchasing a computer with product details below for my company. Wondering if it will run Autocad LT/ Revit LT suite 2018, without a dedicated graphics card. Looks like it has shared graphics with 12 GB of total RAM, expandable to 16 GB RAM.
Product Details
Item #801413
OfficeMax #25597649
Manufacturer #I34647403BLK
audio hardwareWaves MaxxAudio
BluetoothYes
brand nameDell
Carry Handleno
diagonal screen size23.8 inches
frontside bus speed2,400 MHz
Gamingno
Graphics TypeShared
hard drive capacity1 (1000GB)
hard drive typehard drive
integrated speakersyes
Liquid Cooling Systemno
manufacturerDell
maximum memory capacity16 GB
Maximum Turbo Speed3.50 GHz
memory12 GB
memory card readeryes
memory typeDDR3L SDRAM
microphone jackyes
modelInspiron 3464
modemno modem
operating system detailsWindows 10 Home
Operating SystemsWindows 10
optical driveDVD-ROM/CD-RW combo
peripherals includedcamera; keyboard; monitor; mouse
portsUSB 3.0; USB 2.0; HDMI
processor brandIntel
processor modelCore i7-7500U
processor speed2.70 GHz
processor typeIntel Core i7
Product Conditionnew
Product LineInspiron
screen resolution1920 x 1080
Touchscreenyes
TV tunerno
warranty length1-year limited
wired connectivity10/100 Ethernet
wireless connectivity802.11a/b/g/n/ac; Bluetooth
Message 10 of 11
pendean
Community Legend
Community Legend
It's an average hardware setup for an average cad user.
Message 11 of 11
john.larmor
Thank you, this seemed to have actually remedied keyboard input lag for me. Doesn't make sense but must have come about when AutoCAD attempted to get fancy with visual menus / windows / fading.
Not something one would want to turn off, because it's really one of the few new features in more recent versions, but it did seem to make the difference for me. No more, entering keystrokes again and hitting space bar twice.
