- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This has been an ongoing and very frustrating problem for me. I will create a drawing and save it, then when i open it at a later date, the entire drawing has rotated 1-2 degrees. For example, I will draw a series of objects with 90 deg lines, save, then close the drawing. Upon reopening later, the lines are now 89.2 deg or something to that effect. This also occurs on opening drawings others have done that I open on my machine, including those done on earlier versions of LT. It happens randomly, so I have not found any pattern or time period. So far, I have not been able to fix a drawing and am usually forced to start over or correct hundreds of lines.
Anyone else having this problem? Is this a bug in the software? Am I unknowingly hitting some hot key or command that I am unaware of that rotates everthing? At the very least, does anyone know a quick way to rotate an entire drawing a fraction of a degree?
