Hi, Jessica,
the only possible solution as I see is to use 'manual' profiles ...
I will explain:
AutoCAD uses many profiles, saved in the Registry UNDER
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R15.0\ACAD-1:409\Profiles\
lename>
AutoCAD LT uses a single, fixed profile named
LT\R8\ACLT-1:407\Profiles\<> or similar (I have a German LT)
If you would like to manage, multiple profiles, you may export that Registry
key into a *.reg file;
then, you can manually edit the profile (or even edit the profile's
parameters under "Options"),
then save the modified profile with different *.reg filename ....
To activate a particular profile, simply doubleclick the *.reg file and
import this settings into the Registry (LT must not run at this moment !).
I hope, this yould help a bit
Greetings
Torsten Moses
