AutoCAD LT FATAL ERROR: FATAL ERROR: (0x7fffeac10005) after opening DWG files
skristianandre19
Message 1 of 8
skristianandre19
Hi! Has anyone experienced "AutoCAD LT Error Aborting " after opening some DWG files?
This started to happen after opening a file with a locked external reference.
Not sure if the reason it started is me setting a new custom Layout template or if it has something to do with the External reference file.
Replies (7)
Message 2 of 8
h_s_walker
Try opening the External reference on it's own. If it opens do an AUDIT on it and say YES to fix any errors.
Try opening a drawing without an external reference and see if that crashes.
Howard Walker
Left Handed and Proud
Message 3 of 8
pendean
Community Legend
Community Legend
@skristianandre19 "some drawings" usually means you ought to be using RECOVER command to open those files (use RECOVERALL command to open files that also contain XREFs) to fix them: start there ASAP.
Additional ways to fix problem files individually are... https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...).
HTH
Message 4 of 8
skristianandre19
Thank you for the recommendation. I tried to open the External reference and Fatal Error happens right after. I checked the Autodesk error and this list shows up:
AutoCAD LT Error Report Details
Error signature
・Application: AutoCAD LT
・Version: M.49.0.0(x64)
・Error: Unhandled Exception
This error report includes the following:
・Operating System name and version
・Product name and version Graphics configuration driver name and version
・Applications that were loaded when the error occurred
・Active command when the error occurred
・Computer name (if enabled via the Deployment Wizard or the CAD Manager Control utility)
Message 5 of 8
skristianandre19
Thank you for the recommendation. I think it's not a file issue. The error even happens even if I just start to open a new blank file by using the open command/QNEW it goes directly to my templates folder and as soon as I click one of those templates the FATAL Error is triggered again. Autodesk shows this list for Autocad LT Error Report Details:
Error signature
Message 6 of 8
h_s_walker
Do a repair reinstall of AutoCAD and see if the problem goes away
Howard Walker
Message 7 of 8
WeTanks
can you share the file?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 8 of 8
pendean
Community Legend
Community Legend
@skristianandre19 wrote:
Thank you for the recommendation. I think it's not a file issue. The error even happens even if I just start to open a new blank file by using the open command/QNEW it goes directly to my templates folder and as soon as I click one of those templates the FATAL Error is triggered again....
Good to know - then you need to do one of the following:
  1. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhand...
  2. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
  3. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-repair-Auto...
HTH
