Hello everybody.
Is it possible to use a program written in c# inside AutoCad LT? If yes, how?
Thanks a lot, bye.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Use of a c# program in AutoCad LT
I'm not sure if it will or not. I had to use DDE on a program written in VB6 to get it to work with LT 2016, but when I did get it working. The command to start it in LT is below
^C^C_ai_startapp steel.exe
Steel.exe is the name of my program
Howard Walker
INSIDE = No
OUTSIDE = Yes
You can do whatever your wand, but inside AutoCAD LT the only thing you can do is fireing native command input
Sebastian
