- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I've just installed the new AutoCAD LT 2025, and i wanted to use the Ersi Imagery feature, which when you use it prompts you to select an gis coordinate system.
But the problem i'm facing, which is probably because of my lack of knowlegde, is when i get the imagery in the drawing, it does not use the gis coordinate system i set to display the object coordinates in the drawing.
I bacically just want to use the gis coordinates system and the units for the gis coordinate system in the drawing, and when i select an object, it displays the coordinates according to my set coordinate system. And the drawing origin should be at the coordinate system's origin, and not in some arbitrary location in the drawing.
Does this make sense?
