AutoCAD LT 2019 - settings keep resetting
marcus2ZALU
marcus2ZALU
Hi forum,
I am having a problem where whenever I start AutoCAD LT 2019 then my settings/preferences are reset. Settings such as autocomplete, autosuggest, selectioncycling and my UI/layout.
I have tried reinstalling AutoCAD LT 2019 which has not helped with my problem. My colleagues and I use two extensions; CADSTA and Land4, but they have no problems with their settings resetting. So I am not sure if the extensions are the cause of the problem. I have also tried reinstalling them.
pendean
Community Legend
Community Legend
>>>...My colleagues and I use two extensions; CADSTA and Land4...<<<
Unload those and test again, no one here has those so you are kind of on your own at the moment.
In the meantime, ensure you have LOCKUI turned off, you manually save to your active workspace using WSSAVE command after you make UI changes, and if those do not help reach out to your IT folks, your Windows Registry is either corrupt of your limited WIndowsOS log-in is not letting you permanently save your system level settings, or you have a "registry cleaner" that is running quite aggressively to trip you up every single time.
aafzal
DO YOU HAVE CADSTA SOFTWARE?
