After importing hatch patterns previously used in older versions of autocad lt, autocad lt 2019 freezes when I try to use them. It seems I can only use the limited hatch patterns that come installed. It is not an issue of the pattern being too dense or the drawing being too big. After installing the patterns and creating a link to them via support file search path, they appear in my hatch pull down menu, but quickly freeze the drawing after being applied.
Solved by pendean. Go to Solution.
It happens in all drawings. If I open drawings created in autocadlt 2018 (with any imported hatch) the drawings freeze. If I create a new drawing using aclt 2019 and add more than a couple of instances of imported hatch, the drawing freezes. I have scoured help looking for a solution but nothing seems to help.
