AutoCAD LT 2018 Fatal Error
Message 1 of 10
I'm Facing a problem with AutoCAD LT from REVIT LT Suite;
Problem Description:
After about 10 Minutes (The Time Varies from user to another)  , the CAD Suddenly Freezes and show "Fatal Error" Message.
PC Info:
I have the latest Intel Graphics Driver.
PCs RAM : 4GB
Processor: Intel Core i5-6600 CPU
Replies (9)
Message 2 of 10
markcalloway
Hi @Anonymous
Please can you upload a copy of the error.
________________________________________________________________________________
If you find this post helpful, please LIKE.
If you have solved you issue please mark as ACCEPTED SOLUTION so other forum users can see how to fix this issue.
Follow me on Twitter / Follow me on Linkedin / Blog
Message 3 of 10
Here is the Message that shows, But FYI this appeared in HP Z240 Tower Workstation with Nvidia Quadro K620 2GB VGA Card
https://imgur.com/99nMYua
The Whole Image:
https://imgur.com/8ZMAoNo
Message 4 of 10
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
I'll move your post to the AutoCAD forums, the experts there can provide further guidance on your issue.
Message 5 of 10
Any Idea, what is the reason for that error ???
Message 6 of 10
markcalloway
Hi @Anonymous
As a test can you turn off Hardware Acceleration in AutoCAD, you can use the command 3DCONFIG to find the option.
If this stops the crashing its likely your graphics drivers, try installing the latest or look here for recommended from Autodesk:
https://knowledge.autodesk.com/certified-graphics-hardware
Message 7 of 10
I'll try the above solutions ASAP;
But Now this exception also happened earlier today :
https://imgur.com/8PeGRCk
For Your Info we have Dell Sonic Wall in our Carvans
Message 8 of 10
Hello, I didn't get an answer for the second picture !!!
Message 9 of 10
markcalloway
The error in the second picture is likely the result of the same issue.
How did you get on.
Message 10 of 10
pendean
Community Legend
Community Legend
Did you turn off hardware acceleration in GRAPHICSCONFIG command as directed to do so earlier? Do it now on all PCs since you now seem to be replying on behalf of more than one user.
You need to find out what command/function triggered the problem, error messages mean nothing for most of us; if the crash simply happens all the time at the 10-minute mark, start digging on each PC and the server to see what happens every 10-minutes on those PCs or on the server.
One more time: The error messages mean nothing to anyone in these forums, we are not "autodesk" and those that are here are not from the program coding department.
You also need to ensure all LT2018 seats are fully patched and updated: current version in ABOUT command should shoe LT2018.1.2
