Autocad LT 2017 slow
info
info
Since new installation autocad LT 2017 seems really slow..
when i stretch somes lines
when i copy or moves block and lines
when i work with hatch
it lags so much that when i do a move, usually i can do: move, select block, specify base point, zoom out/in, specify second point
but the lag causes a conflict with the zoom and the specify second point so the block moves randomly. To prevent this i must wait like 2 or 3 second between each step wich is really not productive.
With previous version i had a similar issue but with modifications to somes parameters i was always able to resolve the issue. But now it dosen't seem to work. I tried to play with hardware accelaration on/off, with selectionpreview, selectioncycling and some other variable without any success..
Do you have any other suggestions ?
Thanks a lot
Charles_Shade
Video card within the specs of LT2017?
What was your previous version #?
pendean
Community Legend
Community Legend
Autodesk thinks it might be this http://knowledge.autodesk.com/article/AutoCAD-LT-2017-extremely-slow-since-install
So, does this happen in ALL files, even if you start a new blank empty file?
or is it actually limited to the one file you are in, or a few from the same project or source?
What previous version did you have?
What is your Windows version? What is your video card?
Emmsleys
Has the been other updates to your graphics card that have been released?
What are you running AutoCAD LT 2017 on Windows 7,8,10?
Sarah Emmsley
Technical Support Specialist
Emmsleys
Hi @info
Following up on your thread, if you have the time and are still having an issues with AutoCAD LT 2017 performace post back.
Or select Accept as Solution if any post in this thread resolves your issue.
Thanks.
Sarah Emmsley
