AutoCAD LT 2017 - Polyline highlighting when selected
ed_perryman
Message 1 of 19
ed_perryman
Seem to have a an issue in 2017 where polylines with width are not being highlighted when selected or moved. (the grips still appear when selected but the lines used to go fuzzy (for the want of a better word!)) See screenshot comparison with 2016.
Is there a setting that has not migrated properly or is this a bug?
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
Is HIGHLIGHT variable turned on? explained in HELP. Otherwise I cannot repeat the issue here in LT2017 but I did not migrate from an older version either:
Message 3 of 19
ed_perryman
Cheers for the reply. Did a bit of digging when you pointed out yours worked, tried a colleagues computer and on the face of it that seemed ok too.
Then realised I'm a bit old school so I have selectioneffect set to 0. Setting it to 1 fixes the polyline highlight issue but I prefer the dashed lines with selection effect off.
Tried setting colleagues machine to my settings and the same issue then occurs. So on the face of it something does appear to have changed between the versions.
Message 4 of 19
pendean
Community Legend
Community Legend
I'm a user of SELECTIONEFFECT so that explains it.
Message 5 of 19
stevetamplen
Hello ed.perryman, and welcome to the Forums!
It sounds like this was just a settings issue.
If you think Dean's post solved the problem (as it appears it did), then please click Accept as Solution for his post.
Steve Tamplen
Technical Support Specialist
Message 6 of 19
ed_perryman
Hi Steve, It's not a settings issue per se, the notable point that came out of Dean's post being that I work with selection effects turned off.
In 2016, this was not a problem, polylines with width had a visual indicator when they were selected, in 2017, this no longer happens.
Message 7 of 19
stevetamplen
Have you tried setting COMMANDPREVIEW to ON?
That should allow the 2017 highlighting to remain the same as in 2016.
Steve Tamplen
Message 8 of 19
ed_perryman
Hi Steve, thanks for the reply, COMMANDPREVIEW is already on unfortunately.
Message 9 of 19
h_s_walker
Have you checked you Visual Effect settings?
OPTIONS
SELECTION TAB
At the Bottom Left is VISUAL EFFECT SETTINGS. Click on that. What are your settings?
This was looked at in LT2012. I assume the dialog boxes have stayed the same
Howard Walker
Left Handed and Proud
Message 10 of 19
ed_perryman
Hi there, thanks for the reply, see attached screenshot, settings between 2016 and 2017 are identical.
Message 11 of 19
h_s_walker
Looks like they've moved / deleted the setting. This is LT2012
Howard Walker
Message 12 of 19
h_s_walker
Just had a quick read up on the variable.
Is Hardware acceleration on or off?
Howard Walker
Message 13 of 19
ed_perryman
Ah, interesting. Hardware acceleration is on in both versions, and both High quality geometry and Smooth line display are ticked.
If I untick High quality geometry in 2017, polylines then display correctly when selected.
Message 14 of 19
h_s_walker
Sounds like a graphics driver issue
Are they the same graphics card in both machines?
Howard Walker
Message 15 of 19
ed_perryman
Both versions runnning on the same machine! Tuner logs are identical.
Message 16 of 19
pendean
Community Legend
Community Legend
The graphics engine in 2017 was tweaked: so it's not quite the same as 2016.
other than trying to find a driver at Autodesk for 2017 I'm not sure there is much else you can do http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Message 17 of 19
stevetamplen
Well, the weird thing is I can get AutoCAD 2017 to display correctly (like 2016, showing the Plines as highlighted), but even with the exact same settings, AutoCAD LT 2017 will not...this should be possible...maybe I missed a setting somewhere.
Never mind, I did miss a setting.
With HQ Geometry turned off, the lines display correctly (fuzzy) in both 2017 and 2017 LT.
Steve Tamplen
Message 18 of 19
stevetamplen
@ed_perryman
Did changing that setting work to get the highlighting to display correctly for you as well?
Please post back to let me know.
Steve Tamplen
Message 19 of 19
ed_perryman
Hi Steve, yes unchecking HQ geometry "fixes" the issue. Not really a solution though as it worked o.k. in 2016 with it on. I'll wait and see if an updated driver is released at some point.
Cheers
Ed
