Autocad LT 2016 View Ports
Do view ports exist in Autocad LT 2016?  How do you select views in Model space and move them to Paper space?
rkmcswain
Yes.
Switch to a layout tab, type in the command MVIEW. Pick two points to form a rectangle, that is your viewport. Double-click inside the viewport to change to model space. On the View Ribbon tab, in the Views panel, find your named view and select it. This will change the view inside the VP to that view. You can lock the viewport after that to prevent zoom/pan changes.
R.K. McSwain     | CADpanacea | on twitter
Thanks for the information. It was just what I needed.
Michael Tiazkun
RiteScreen Co.
4314 Route 209
Elizabethville, Pa. 17023-8438
Phone: 717-362-7483 Ext 2588
[email protected]
CONFIDENTIALITY NOTICE: This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. This message contains confidential information from The RiteScreen Company, LLC and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
