Autocad LT 2016 - fatal error
informatykaN5RP8
informatykaN5RP8
i have a problem with my Autocad LT 2016 version on Win 10. 2 weeks ago it was working fine but now - on startup, the program freezes while loading acadltiso.dwt. The process is aborted and a window pops up with a fatal error: Unhandled Access Violation Writing 0x8b521000 Exception at 28d9c89fh. Any ideas how to fix this?
Thx for help. Regards
paullimapa
Perhaps your acadltiso.dwt is corrupted?  To test remove or rename that drawing template file from your profile to see if AutoCAD LT will now open successfully
Paul Li
IT Specialist
@The Office
WeTanks
The updata of W10 will affect the use of the old version
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
h_s_walker
@informatykaN5RP8 What version of Windows 10 are you using? Hold down the Windows key and press R then type winver and paste a shot of the dialog box that pops up. See the image below
Howard Walker
Left Handed and Proud
informatykaN5RP8
Win 10 Pro
Version 22H2 (OS Build 19045.2965)
Regards
h_s_walker
@informatykaN5RP8
I've attached my copy of acadltiso.dwt. I am also on LT2016 and the same Windows 10 version as you and have no problem opening the file.
If you cannot open this file I would suggest a repair reinstall
Howard Walker
informatykaN5RP8
hello,
my problem has been solved. The drivers for my uhd 770 graphics card generating errors. When i installed a different version of the driver everything went back to normal. Thank you all for help. Regards
