Just upgraded and when trying to print (plot) a .dwg file instead it prints to the plotter an 'Error Condition!' with an Invalid File result to a path that does not exist. Help-
Printing to Kip 3100
Installed as a system printer, but the driver is installed locally
Yes, using a pc3 file
Yes, Kip is on the network
No physical attachments
Exported a .dwg to .pdf and printed to another network printer OK..
Th operating system is still the same Windows 7 Pro 64-bit..
It did have a previous version, AutoCAD LT 2011 (which is still there).
The previous version worked fine for the previous user. I am told by the new user of that machine, that he has never been able to print any drawings to the KIP. When the user was set up on that workstation, 2011 was installed and tested fine. Not sure what could have happened.
Does anybody have any ideas? Is there someplace that a default path is saved?
The same version of AutoCAD works fine on other machines that are configured the same with the same KIP driver.
It will print to the KIP, however, it prints an 'Error Condition' and displays a path to the file that does not exist (exact for the filename trying to print).
Sorry, I've been out. I will try the suggested and get back to you.
Thanks.
