AutoCAD LT Forum
AutoCAD LT 2014
7 REPLIES 7
Message 1 of 8
464 Views, 7 Replies
AutoCAD LT 2014
What happen like this ?? any solution ???
7 REPLIES 7
Message 2 of 8
Charles_Shade
Welcome to the Autodesk Forums!
Assuming the white spot at the top that may be a graphics issue.
Are you looking for the drop down Menus?
Have you changed the CUI in some way?
Message 3 of 8
braudpat
in reply to: Charles_Shade
Hello
Very strange !?
Have you tried to :
- Disable Hardware Acceleration ?
- Upgrade your graphic card driver ?
- Install the SP 1 for ACAD LT 2014 ?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22264544&linkID=9240818
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 8
Hi
Thanks u reply
nope , me is first time using this notebook , i no change anythig .
when i update to SP1 , for the right side ribbon is show out now , but the left side ribbon always hidden like this
if is the setup probelm , can guide me ??
Message 5 of 8
in reply to: braudpat
Hi
thanks u replay
all i try ald
but still can't solve
Spoiler
Smiley Sad
Message 6 of 8
inchul.lee
Hi IPESWITCHBOARD,
The area is where 'Quick Access Toolbar' is and commands like New, Open, Save, etc. are located. As Charles and Pat already replied to you in the above, it could be a graphics issue or corrupted customization issue.
Normally, product repair or reinstallation will resolve such issues, but please perform graphics driver update and run 'Reset Settings to Default'.
Thank you.
Inchul Lee
Message 7 of 8
in reply to: inchul.lee
Hi
Thank u reply
ok , i try ald , but still like this
this version can support win 8 ???
Message 8 of 8
pendean
The QAT is what goes there: can you right-click on it and get a menu pop-up? graphics card hiccup perhaps? You are working n a laptop, with no additional information, that's probably a starting point to review. Win8 is not the problem.
Or as note earlier, you're chosen workspace has the QAT missing?
Do you need the QAT? you did not know about it so my guess is not.
CUI command, QAT stands for Quick Access Toolbar: expand that category, select your active workspace, click on CUSTOMIZE WORKSPACE and see if there is a check mark next to the QAT1 entry.
Uncheck it and live without it for now. Save your workspace.
Look up QAT in HELP in LT2014.
”Boost
