I have drawn an oblique line in Model Space and wish to reduce it to a particular length. I have opened the line properties menu and find that the length is greyed out. Can someone please tell me how to make this box active so that I can edit it? Thank you.
Bill A
[ The subject line of this post has been edited for clarity by @handjonathan Original: Editing line length ]
I have a similar situation. Before in AutoCAD 2013, If i watned to change the length of a line segment I would simply select one end of the line, move the cursor in the direction I wanted (wether it be to lenghten the line or shorten the line), enter a distance vaIue and it would change the line according to that value.
Now, we recently upgraded to AutoCad 2015 and with this program that is no longer the case. If i click one end of the line segment and move the cursor in the desired direction, like before, and enter a distance value, the line segment becomes that length instead of changing the length.
Example: I have a line segment that is 100'-0" long. I want to increase length by 6". So I pick on end and move cursor accordingly, I enter the value 6" and the line now becomes 6" long.
I could use the lengthen or stretch commands, but to me the "click, drag, and enter distance" works faster.
A co-worker of mine had already fixed this problem for me by changing the value for a certain system variable. He doesn't remember and I don't remember which one it was? Could any one help?
Good point about habits formed on other software. I orgincally learned on Autocad 2000, but then went the engineering route and thus use Fusion 360 and Solidworks now (which I loathe). Knowing where your points are before you draw your lines is great and all, but now there are ways to draw walls automatically like in Architecture 2022, I wonder why we still have to delete/redraw entire walls when we figure out we need to move something 1/2" or to make a gap equal to 6 1/4" versus 6"? I think this is what the OP was getting at by saying they don't understand why such a program has the ability to change dimension values.
Do you know if there is a way to accomplish this so that the dimensioning style is similar to that of, say, Autodesk Inventor? It would make drawing sections and sketch blocks much easier, and would allow for quick design changes when large, complex models/drawings are needed!
Thanks in advance
