AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
autocad lt 19 save creates xps file
3 REPLIES 3
1050 Views, 3 Replies
autocad lt 19 save command creates unwanted xps file
3 REPLIES 3
pendean
I suspect that is not the case: turn on file extensions in Windows File Manager and confirm exactly the file types you are looking at, here is how to do that https://www.youtube.com/watch?v=PoTah9YBG2Y
Once you can see DWG and BAK file extensions everywhere, then the job gets a little tricky on how to remove XPS file association with those file type, something like this https://www.thewindowsclub.com/change-file-associations-windows
HTH
in reply to: pendean
AutoCAD LT 2019 saves correctly as dwg. Association is correct. Problem is that a XPS Document (.dwfx) file is created along with a plot Text Document (.log) file. Question is how to stop this. Thank you.
pendean
I wonder if you have AUTOPUBLISH turned on (that you need to turn off) https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Technology Administrators
