AutoCAD Lagging
AutoCAD Lagging
archliker
Message 1 of 20
AutoCAD Lagging
archliker
I’m using AutoCAD Lt 2025 and I lease the software. With every command, when I select something it takes 3 to 5 seconds to select or pick.  This happens with a new file with just a few lines and a large set of plans. It really slows me down. I do not believe it has anything to do with existing files vs new files. They both do it.
I’ve checked everything for updates and it’s all good. It didn’t seem to be as bad when I bought the laptop about 21/2 years ago. I probably used release 2021. (not sure if that matters)
I use (2) 27” (1920 x 1080 ) external monitors along with the Laptop monitor. I’m including my specs and AutoCAD ‘s requirements below. I’ve read some posts from other people, and they were apparently able to fix the problem but I haven’t.
By the way, I am not on a network, Thanks!
LAPTOP SPECS
Intel i7-9750H CPU@ 2.60 GHZ   2.59 GHZ
32 GB RAM, 64 bit OS, x64
Windows11 pro, version 23H2, Installed 8/21/2923, OS Build: 22631.4391
Windows experience pack 1000.22700.1047.0
Processor
The Intel i7-9750H is a 9th-generation mobile processor. It is part of Intel's Coffee Lake Refresh family of processors, which was announced in October 2018.
Here are some specifications for the i7-9750H:
  • Cores: 6, Threads: 12 -  Max turbo frequency: 4.50 GHz - Base frequency: 2.60 GHz
  • Cache: 12 MB Intel Smart Cache - Bus speed: 8 GT/s - TDP: 45 W
  • Max memory size: 128 GB - Memory types: DDR4-2666, LPDDR3-2133
System requirements for AutoCAD 2025 including Specialized Toolsets (Windows)
Operating System
64-bit Microsoft® Windows® 11 and Windows 10 version 1809 or above. See Autodesk's Product Support Lifecycle for support information.
Processor
Basic: 2.5-2.9 GHz processor with 8 logical cores (base) ARM Processors are not supported.
Recommended: 3+ GHz processor (base), 4+ GHz (turbo)
Memory
Basic: 8 GB
Recommended: 32 GB
Display Resolution
Conventional Displays:
1920 x 1080 with True Color
High Resolution & 4K Displays:
Resolutions up to 3840 x 2160 (with "Recommended" display card)
Replies (19)
Message 2 of 20
paullimapa
Could be your graphics card....I didn't see on your OP what graphics driver you're using on your laptop. Check this site to see if your graphics card is certified and then download the driver.
If your graphics card is not listed, in AutoCAD enter at the command line:
GFXDX12
and set that to 0
Then close & restart AutoCAD and see if that makes a difference.
If not at the command line enter GraphicsConfig and set 2D Display Settings to another option and see if that helps.
Paul Li
IT Specialist
@The Office
Message 3 of 20
archliker
I DID THIS SUGGESTION
"GFXDX12 and set that to 0" What did I do?
Seems faster but I will let you know later in the day as it gets slower after a while.
THANKS!!
Message 4 of 20
pendean
Community Legend
Community Legend
Message 5 of 20
archliker
Hi, Sorry but this didn't help at all.
Message 6 of 20
paullimapa
Did you download & install LT 2025.1.1 update?
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=AUTOCADLT_2025_UPDATES
Paul Li
IT Specialist
@The Office
Message 7 of 20
archliker
Hi, I just updated and no change!
Message 8 of 20
paullimapa
unplug your 2 external monitors and just use the laptop screen..any difference?
keep your laptop plugged in to the power adapter...any difference?
Paul Li
IT Specialist
@The Office
Message 9 of 20
bilalvarma
Observer
Observer
hi, what was the outcome?
Message 10 of 20
archliker
Hi Paul,
There is a difference. There's still a little lag, but it's better.
What does this mean? My computer can't really handle the other monitors?  Is there a workaround? If it's the graphics card, can they be replaced? (This is a laptop)
Thanks for you input.
Steve
Message 11 of 20
paullimapa
Well, what kind of device are you using to make it possible for your laptop to plug in two more external monitors?
The bottleneck could be there.
Paul Li
IT Specialist
@The Office
Message 12 of 20
archliker
LAPTOP SPECS
Processor
Operating System
Processor
Memory
Basic: 8 GB
Recommended: 32 GB
Display Resolution
Message 13 of 20
paullimapa
Nice to know the specs but that still doesn't tell me how you're connecting two external monitors to it.
Are you using a USB or HDMI extender?
Paul Li
IT Specialist
@The Office
Message 14 of 20
archliker
I misread your message...I have the 2 monitors directly plugged in, one with a hdmi and the other is a display port
Message 15 of 20
pendean
Community Legend
Community Legend
@archliker wrote:
...it's the graphics card, can they be replaced? (This is a laptop)...
No, never with a laptop. Sorry.
What is the make and model of your laptop?
Message 16 of 20
archliker
would a docking station help? I've tried some that didn't work at all
Message 17 of 20
paullimapa
Perhaps it’s time to invest in a new laptop with more powerful graphics capabilities that would better support two additional external screens
Paul Li
IT Specialist
@The Office
Message 18 of 20
pendean
Community Legend
Community Legend
It helps if your two external monitors are 100% identical in every aspect.
Does your laptop have a powered USB-C port? Then all you need is a gadget like this to run two monitors with, if you still have issues, you need a new laptop (see your issue with docking stations)
Message 19 of 20
archliker
My laptop has a USB-C port but I'm not sure if it's powered. Is there a way to tell? I had  a powered docking station which just stopped working.
I probably didn't have as much lagging then, but I had different monitors. Now I have 2 new identical monitors. Maybe I should try the docking station again? The laptop is no more than 3 year sold.
THANKS!
Message 20 of 20
pendean
Community Legend
Community Legend
@archliker it should be just fine then, give it a try.
You can also open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
