AutoCAD freezeds when trying to place attachment (attach command).
When I try to attach a file (pdf underlay) CAD freezes. It freezes before the Windows explorer window opens to select a file. I have tried uninstalling and reinstalling with no changes. All other commands seem to work without incident.
AutoCAD LT 2012
Windows 7 64bit
Accepted solutions (3)
Emmsleys
Do you happen to have Dropbox installed on your system ?
Sarah Emmsley
Technical Support Specialist
Emmsleys
It appears DropBox came out with an update over the weekend that may cause issues opening files when using older versions of Autodesk products. We have heard from our customers that the issue may present as:
-          Crashing
-          Freezing
-          Lagging
-          Product unable to open at all
-          Give an error of “Not Responding”
-          Unable to save new files
This article walks you through removing DropBox and doing a restart. It appears reinstalling Dropbox does not fix the issue, so we advise waiting until a patch is released by DropBox.
Sarah Emmsley
pendean
Community Legend
Community Legend
Dropboxwas the problem. Uninstalled and AutoCAD works fine!
Thanks!
