Some hatches (not all) become invisible that couldnt see in my autoCAD 2018, some coworker use 2014 see the hatches but I dont.
What is this issue? How to fix it?
or should do some command? I use command Fill-ON already.
Thanks.
In AutoCAD Release 14 and later, the FILL command and the FILLMODE system variable control the visibility of hatches, multilines, traces, and wide polylines.
Command: FILLMODE
Enter new value for FILLMODE <1>
Command: HPMAXLINES
Sets the maximum number of hatch lines that are generated in a hatch operation.
Values can be set at a minimum of 100 and a maximum of 10,000,000
should work after REGENALL
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hi @Anonymous,
I see that you're posting for the first time. Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD LT forum.
I'm just checking in to see if you need more help with this. Did the suggestion that @jayhar provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
