AutoCAD LT Forum
AutoCAD 2016 LT Extension Problem
7 REPLIES 7
Message 1 of 8
jayhar
747 Views, 7 Replies
hi, i am working AutoCAD 2016 LT version, here Extension Line cannot see or  working when i pick two points.
please help.....
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
7 REPLIES 7
Message 2 of 8
chriscowgill7373
in reply to: jayhar
It is difficult to understand the issue you are having.  are you referring to extending a line or the extension lines of a dimension style?  Are you able to post some screenshots, a screencast, or the drawing itself?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Message 3 of 8
jayhar
in reply to: chriscowgill7373
WHEN I CLICK TWO POINTS EXTENSION LINE CANNOT SEE, VERSION IN AUTOCAD 2016 LT
Message 4 of 8
chriscowgill7373
in reply to: jayhar
When I use the extension on my system, the dashed green line that appears on the screen is the extension:
Message 5 of 8
pendean
in reply to: jayhar
Can you explain what it is you are trying to ultimately achieve?
Looking only at your screenshot it appears to be working as designed (see the work extension in the pop-up? it's there in action)
Message 6 of 8
jayhar
in reply to: pendean
Hello Pendean,
    1.Can you explain what it is you are trying to ultimately achieve?
           when i click first, & second point direction Extension line does not appears using version in AutoCAD 2016LT.
   2."Looking only at your screenshot it appears to be working as designed (see the work extension in the pop-up? it's there in action)"
           Using Version in AutoCAD 2016 LT will not work. i am working  in another computer & version.
when i move to second point Extension line does not appears
Message 7 of 8
hwalker
in reply to: jayhar
Do you pause for a second over the point and then move, or do you just move to the endpoint and immediately move?
Howard Walker
Left Handed and Proud
Message 8 of 8
chriscowgill7373
in reply to: jayhar
can you record a screencast of your workflow?
Do you have all updates installed for 2016 LT?
Here is what I was able to do with 2016 LT:
http://autode.sk/2slKKTA
Technology Administrators
