AutoCAD LT Forum
AutoCAD 2012 LT license activation with LTU tool
6 REPLIES 6
1282 Views, 6 Replies
I received a new laptop at work which doesn't have cd/dvd drive. In my previous laptop AutoCAD LT 2012 was installed from cd. How can I get 2012 LT version that I can download form internet so I can then activate it with LTU tool? I downloaded 2016 LT trial but of course it wasn't possible to activate with older version license.
Is the only option to buy an external cd drive and install 2012 LT from there? It's a bit odd that you can't download older versions from Autodesk website. This is propably quite common issue as older laptops did have cd drive but new ones doesn't have and it will end in very annoying situation.
6 REPLIES 6
camilo.lemos
Hi @Anonymous
I would suggest that you contact our customer service crew as they may be able to help you obtain this link.
You can contact the customer service team by clicking on this link and selecting Downloads & Upgrades > Finding a Download. Once the page fully loads, you'll be able to contact the team via a support form or via chat if agents are available.
I hope this helps!
Camilo Lemos
in reply to: camilo.lemos
Thanks for your quick reply!
I found older version back to 2013 but there was no 2012. I try to get my hands on external cd drive and if evn doesn't work then I will contact reseller. Thanks again!
camilo.lemos
You're welcome!
Camilo Lemos
pendean
My 2cents worth... You'll find that just buying a CD drive is cheaper and quicker IMHO. Good luck.
in reply to: pendean
Okay, external hard drive solved the problem, phew.
But still thinking out loud that when using LTU tool you need some sort of AutoCad isntalled on your machine. If you are running an older version and you have installed e.g. latest trial version (older version are very hard to find from Autodesk site) then when using LTU to transfer a license it would be great if it would recognize that your license is for older version and then it would automatically install the correct version.
But anyway, thanks for the repliers and for your help, much appreciated!
pendean
Keep in mind that Autodesk stops hosting downloads of older software annually: so your LTU wishlist will always fail if you are more than 3-versions back.
Technology Administrators
