Welcome to the Forums
Copied from https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Preven...
Issue:
When you mirrored a block containing text, the text was mirrored even though the MIRRTEXT system variable was set to 0.
Causes:
The MIRRTEXT system variable affects text that is created with the TEXT, DTEXT, ATTDEF, or MTEXT commands. Text and constant attributes within an inserted block are mirrored as a consequence of mirroring the entire block.
Solution:
To work around this, include your text in the block as an attribute instead of as text. To prevent the attribute text from being mirrored, verify that in the Attribute Definition (ATTDEF) dialog box, under the Mode section, the Constant option is not selected. This option is also available on the Properties palette under Misc.
If MIRRTEXT is set to 0 and an attribute within a block in not Constant, the attribute text will not be mirrored when the block is mirrored.
Howard Walker
Left Handed and Proud
