Hi Gents,
Is there anything a lisp or script that acts as ATTIN for AutoCAD LT. Does the ATTOUT.lsp include the attin command when i "appload" it in the LT will it work or not?
Because i have a Txt file and i want to update the Atributes but LT won't allow me due to it doesn't have the ATTIN command.
Thank you and regards,
Tramyer
Solved by steven-g. Go to Solution.
Tramyer,
AutoCAD LT does not support Lisp.
Therefor there is no way to do so. You can only do it manually.
This is LT so no Lisp, ATTIN or ATTOUT, but there is ATTEDIT, and if you have nothing else it can help. Take a look at this thread and see if it gives you any ideas, if you get stuck then post a copy of the txt file and a drawing with the attributed block and someone will possibly be able to nudge you in the right direction.
