@info schrieb:
Our machine has accepted the standard ARRAY created from the functions located on the RIBBON panel before this leading me to assume this is a more recent issue.
Perhaps you saved the files in an older DXF format? (see may answer above)
It is also not only the machine that is reading them as blank files.
TurboCAD Pro also doesn't recognize them.
Perhaps TurboCAD have a similar problem (Turbocad uses also not a native DXF interface, it's just a try to copy the file format from Autodesk)
However both the WJ Machine & Turbo cad had no problems opening the files made using the ARRAYCLASSIC command.
What is the difference between the two commands (ARRAY & ARRAYCLASSIC)
As i wrote above:
"Classicarray command is nothing more than a special COPY command,
the newer array command creates a new object - an object type "ARRAY"."
Short: The one copies objects and the other one create one object of a new type, it's like a BLOCK
Do they both output different linetypes.. because there are NO options to change this if this is the case.
What are linetypes to do with the topic? Array ot classic array, both will not change the linetypes
This IS an ACAD issue. As i mentioned. The ribbon panel HAS produced usable files before however no longer does.
No it isn't so long you can open the files in your AutoDESK product without a problem.
Feel free to upload a sample and we can check the content.
Leading me to believe that this is a BUG with AutoCAD.
All what you wrote make sense and i can not read about an issue,
so long i am right you saved the files as an dxf2010 or older format in the past.
