Arrays do not appear when printing or exporting PDFs
Message 1 of 11
When I print or export PDFs the arrays do not appear, any ideas?
Jon
Replies (10)
Message 2 of 11
h_s_walker
Welcome to the Forums
3 things to check
1. The array is not on the DEFPOINTS layer.
2. The Layer the array is on is set to NOT PLOT (a red diagonal line through the printer)
3. The Layer or array colour is not set to 255 or True Colour 255,255,255
Howard Walker
Left Handed and Proud
Message 3 of 11
Checked all those and they are all correct, only using 1 layer, I had to do a graphics card upgrade yesterday and since then the arrays do not appear.
Cheers
Jon
Message 4 of 11
h_s_walker
Sounds like your graphics card is the problem. Can you post the drawing here so we can have a look at it
Howard Walker
Message 5 of 11
Attached, there should be 4 radial slots
Jon Fell
Technical Manager - Power Connectors
Mobile: 07568 429373
Tel: 01384 404488
Fax: 01384 404477
[Description: NEW SIGNATURES Aug 2015]
Registered Office: Unit 5 Gibbons Industrial Park, Dudley Road, Kingswinford, West Midlands, DY6 8XF
Registered in England: 3497874 Vat Registration: 704826244
Email: JonFell@alcomet.net Website: www.alcomet.net
Message 6 of 11
h_s_walker
No file attached. Try putting it in a zip file and attaching that
Howard Walker
Message 7 of 11
Hope you can see the attached?
Message 8 of 11
h_s_walker
I'm talking about posting the actual drawing not the PDF of the drawing. Then we can see if we can recreate the problem or tell you if it is something to do with your graphics card.
We can't help with just seeing a PDF
Howard Walker
Message 9 of 11
dwg file attached
Message 10 of 11
h_s_walker
Got it and I've seen what your problem is.
Explode the array and now select your white arcs. You will see they are on the defpoints layer. Change their layer from defpoints and you will get the attached
Howard Walker
Message 11 of 11
Thanks 🙂
Jon Fell
