AutoCAD LT Forum
Arial Greek font
3 REPLIES 3
1902 Views, 3 Replies
Arial Greek font
I installed Autocad LT 2005 a few weeks ago. I was working with Autocad 2000 for some years and I was using the Arial Greek font to write notes in Greek on drawings. When I open drawings drawn with Autocad 2000 in Autocad LT 2005, all Greek notes are unreadable. They come out in what I discovered yesterday in Unicode characters of Latin letters of the Arial Greek font! I clarify that all new notes written in Arial Greek in Autocad LT2005 are legible. Why is this happening and how can I solve the problem short of re-writing notes on hundreds of drawings?
3 REPLIES 3
It would appear you are dealing with two different fonts: did you at any point copy or reinstall the fonts you used to use in 2000 over to LT? Do you know if it was an SHX font or TTF font? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
It was a TTF font and yes at some stage I did bring fonts from Autocad 2000 to LT but I believe only after I encountered the problem. "Dean Saadallah" wrote in message news:422714d4$1_1@newsprd01... > It would appear you are dealing with two different fonts: did you at any > point copy or reinstall the fonts you used to use in 2000 over to LT? > Do you know if it was an SHX font or TTF font? > > -- > Dean Saadallah > Add-on products for LT > http://www.pendean.com/lt > -- > >
After now means you have a font substitution in place. You will have to redefine your STYLE and re-apply to your text in each file that was opened and saved. If there is a quicker way, someone will post. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Technology Administrators
