My 2018 AutoCad LT toolbar for the Layers pull down shows four Chinese characters at the end of the list. There’s also a Zona Verde one I’ve never created. Anyone else running into this?
Solved by pendean. Go to Solution.
Does it happen in all drawings or only this one? Perhaps you can share the file for everyone to take a look?
Happens in all drawings I remember to check lately, but haven’t gone hunting through every drawing on current projects. I’d say a dozen drawing in the past month.
Not to scare you but it’s possible there’s a lisp code that’s running every time you open a dwg that’s generating these Chinese character layers
More than likely, you have introduced content with those layers.
@BenchmarkArch wrote:
Yes, it's very cluttered. All those layers are inherited from different
operators on different layering systems and a bunch are part of the
original xref from the facility.
Those layers are just more clutter from other files then, Google translated those layer names as
... which seems to support my theory.
You have some serious cleanup to do. Best of luck.
