How to I get rid of annoying popups for every command that get in the way of drafting?
Solved by cadffm. Go to Solution.
Learn more about Dynamic Input method (It's a new feature since 17years)
Toggle On/Off = [F12]
Not your case? Share a Screenshot, because "Popup" means all and nothing.
Sebastian
@BenGordesky wrote:
Some times, when I hit F3 or F8 to toggle Object Snap or Ortho in the middle of a command CAD LT freezes.
Special (or laptop) keyboard perhaps where F3 and F8 actually do something else altogether but to get the toggles you need to have a special button pressed first? very common problem that a user can easily miss.
@BenGordesky wrote:
And, sometimes I miss the ESC key and hit another key, I think it is F1? When I do that the file closes without saving, not even a request to save. Why is that?
What other key? Like my first reply above, your keyboard probably has this feature and you need to find it to turn it off.
IMPORTANT: LT2017 needs to be fully updated: does ABOUT command confirm you have this installed https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
And if you are running in Win11.... that's a major issue in of itself.
HTH
2017.1 was called "Servicepack" and is published public.
Sebastian
@BenGordesky wrote:How to I get rid of annoying popups for every command that get in the way of drafting?
Those "annoying popups" are quite useful for a lot drafters. In fact, some would say, "invaluable". Might want to look into how they could improve your workflows.
