I made a block in Autocad LT 2016 in 1:1 Scale.
I clicked Annotative in behavior as well as make block orientation to layout
When i insert the block into any scale it shows up way larger than it is supposed to
How do i fix this?
Amber
Welcome to the Autodesk Forums!
What is the CANNOSCALE of the Target Drawing AND what is the CANNOSCALE or within the Block Editor or Drawong File where the Block was created?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
My Cannonscale for both the block editor and the target drawings were 1:1
Does the scale that you want exist in the list of Annotative Object Scales?
From Help: To Add Annotation Scales to an Annotative Object
Select an annotative object.
Right-click in the drawing area and choose Annotative Object Scale Add/Delete Scales.
Click Add.
Select the scale add.
Note: Hold Ctrl to select more than one scale.
Click OK twice to return to the drawing.
So what was the solution?
