I have a control panel block that is 0.84' aka 10.08" wide at 1:1 in model space. When I set annotative scales to 1"=20', 1"=60' and 1"=40' the silly thing is like 20 times, 60 times and 40 times wider in paper space. I just can't seem to get it right.
I end up setting it as non annotative and just a consistent width just so it won't look stupid. I'm very new to using
annotative text and can't seem to get the blocks right
Solved by h_s_walker. Go to Solution.
Here ya go
If you have drawn your block at full size in modelspace it does not need to be annotative.
Howard Walker
