- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I needed some annotative blocks with attributes in my project and when I tried to apply them to different scale I came upon this error. Thus, when in annotative block you have attribute with multiple lines checked then if the drawing with that block is loaded as XREF the text simply wouldn't scale together with block but remains in scale which is on top of the list. Lets be clear of one thing, in the drawing the blocks are scaled normally, this problem only appears when loaded as XREF.
The only solution I found is changing attribute to normal one, and for now it works, but in the future i may be in need of multiline style attribute that scale with block if it's loaded as XREF
Thank you for your time
Oghi
