Hi all,
I am a network Engineer trying to plan out Ethernet cabling expansion.
I have CAD files from the property manager.
In the analog world, I have the printed drawings, and just write the cable numbers on the sheet in the approximate location of the jacks.
I would like to learn how to do this in AutoCAD, but I am unsure of what terminology to use to search/describe what I want to do.
So I guess really what I am looking for is bit of help sorting through some of the Docs and targeting what I need; vs going deep into CAD world.
I tried adding text boxes but I see no way to size/move the numbers easily.
Additionally, is AutoCAD LT the correct product to be using?
Screenshot of what I am trying to accomplish.
Solved by pendean. Go to Solution.
Thank you that was exactly what I was looking for.
I had CAD classes way back in the day, sadly my 'learning' schedule is a bit booked. Salesforce now and Server 2019 when it is finally released. Just need the stop gap to knock this project out; I did attempt the getting started here on Autodesk site...
