Recently bought 2 seats for a yearly Subscription of AutoCADLT 2016.
For some reason I can only give access to 1 user and not both?
Solved by camilo.lemos. Go to Solution.
Hi @GalvinAbercrombie and welcome to the Autodesk Community!
Please try following the steps described on the solutions below to Add a User and Set Permissions:
Adding or Removing Users in User Management
Setting User Permissions for Products, Services & Support
I hope this helps!
Thanks Camilo,
Seems the issue was slightly deeper that I originally thought, although Account says there is 2 seats available there is acctually only 1. My service provider has issued a critical case with autodesk so fingers crossed we get things up and running ASAP.
Thanks again for your quick response.
Galvin
You're welcome @GalvinAbercrombie!
I'm sure our Customer Care crew will be able to take care of this for you in no time.
