- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am setting up another computer at the office and sharing tool palletes that I already have on an existing computer.
I export the pallete groups and pallets and import them on the new computer with no problem. Unfortunately when I go to use the blocks on the palletes, it cannot find them.
The blocks are saved on the "E" drive which is a local drive on the original computer. When I try to access the blocks, AutoCAD is looking for an "e" drive on the new computer that does not exist. Instead it needs to look for a "network" drive linked back to the original computer. I can go in and associate all the links to look at the original drive, but there has got to be an easier way. What am I missing?
My goal is ultimately to be able to create the blocks on one computer and be able to replicate them on a second (or even third, fourth, etc). Ideally without having to export and import each time. I thought that by using a single networked drive, that would work, but it isn't the way I was hoping. Is that possible?
I guess to be clear, what I am asking is how do I make the file path for a block that is part of tool pallete relative, not absolute?
Thank you
Dan
topic title has been edited by @Tarek_K for better findability. Original: Sharing Tool Palletes
