AutoCAD LT Forum
ACAD LT 2022 Match Prop not working in pspace
2 REPLIES 2
peta.o
481 Views, 2 Replies
I have recently installed ACAD LT 2022.
I have a problem with match properties - that being that it works fine in model space, but when I try to use it in paper space, the painter becomes invisible. The only way I know where it is, is that the object highlights when I hover over it. This makes it unusable because I can't see what I'm doing. Not helpful.
No smartarse comments thanks - just want a solution. 🙂
2 REPLIES 2
pendean
in reply to: peta.o
Your video card may be choking: Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT2022: reverting to DirectX11 fixes the problem for most users.
If that did not help, turn off hardware acceleration in GRAPHICSCONFIG command.
IF none of those helped, roll back to LT2021 then report the issue through your Account Page here https://manage.autodesk.com/home/ to Autodesk Support (click on the ? icon to get started). No one here is Autodesk Support, we are all end users just like you helping each other out.
peta.o
in reply to: peta.o
Hi pendean,
thanks for taking the time to find a solution for me. It seems to be working so far, so fingers crossed.
ta muchly.
Technology Administrators
