Hello I have Autocad 2020 LT installed. In the latest update it has changed the way I can trim items. In the past I would select what items are to be trimmed and select a boundary for the time, hit enter, then select the portion that is to be trimmed. Now, I hit the trim command and just click on the part that is to be trimmed. How do I revert back to the older way?
Solved by hartacus212. Go to Solution.
as much as i understand .... if you check PICKFIRST = 1 , any changes ?
Imad Habash
Thanks for the answers. I got an email from Chris and this worked.
"Hello Thomas,
My name is Chris, and I would like to assist you with your issue.
TRIMEXTENDMODE when set to 0 will put the trim command back the old way.
https://knowledge.autodesk.com/support/autocad-...
Thank you,
Chris C.,
Autodesk AutoCAD Certified Professional
Autodesk Civil3d Certified Professional
Autodesk Expert Elite"
@PrecisionDesignsSD or in your case, if you don't want change then don't change software versions, otherwise when you change to newer versions of AutoCAD/LT look up WHAT'S NEW in HELP and read all about the newest changes to the program (aka it is not broken)
HTH
Maybe you don’t realize that those who use AutoCAD for a living are forced to update their software versions because old versions of the software no longer support newer versions of DWG file. You also may not realize that some of us who are using the software on a daily basis don’t have time for “What’s New”. And when something that has worked fine for 20 years all of sudden doesn’t…….. It’s broken.
You assume that somoenoe who dosent read the what's new falls flat on their face or in some way dosent know how to use the software but that's not the case at all. Wake up guy. You said it best when you said autoCAD was a tool. Nobody said Don't add new features to the tool. But everyone here said dont change the fundamental way the tool works. Sure add new features that will help speed up productivity but don't change the way fundamentla aspects of the tool works and then make it the new default! It slows down productivity.
Well again, remind me why I'm left fixing something that was never broken to begin with. AutoCAD please take note of this exchange.
Bro you don't gotta lie to kick it. Besides you'd believe that? Sure it make perfect sense. Don't browse the knowelege network to see what kinds of problems people are having this week. Where to trolls like you come from? You must be working for autodesk.
Hi thank you, I like the other features in the newer version, so I'm all happy now.
