AutoCAD Land Desktop (Read Only)
PLOT PREVIEW CRASH
2 REPLIES 2
338 Views, 2 Replies
PLOT PREVIEW CRASH
I have a drawing file which has something within it that caused LDT 2007 SP2, Civil3D 2007 SP2 and ADT 2007, to crash when using “print preview”.
I can plot this drawing file with out any problems if I skip using “print preview”.
I have tried Audit and Restore without any success. How can I repair this file
Jeff
2 REPLIES 2
Does this recalcitrant dwg file contain any images, or something else along
those lines Jeff?
If it has XREFs (Overlayed hopefully, not Attached), then you could Unload
all of them to see if that helps your case?
If you have success once again with Plot Preview, then begin to Reload them
one at a time, to see if you can tell if one of them might be providing the
impetus for your crashes?
If you can "nail down" the likely suspect, then you might go a little
further with your Audits and Recovers?
HTH
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
C3D/LDT/CD-2K7
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5461579@discussion.autodesk.com...
SP2, Civil3D 2007 SP2 and ADT 2007, to crash when using "print preview".
I can plot this drawing file with out any problems if I skip using "print
preview".
file
Jeff
I had the same problem but it went away after I installed Service pack 2a for LDT 2007.
