Please help, I have two questions for Land Desktop Guru....
First: When dynamic label a line, instead of showing N45d03'35"W, the label shows as N 45d3'35" W. The question is how do I set the format for Dynamic label so it doesn't eliminate the "zero" and the space between "N and 45 "and "second sign and W".
Second: After awhile, i think when the autosave kicks in, or about 2-3 minutes, the dynamic label wouldn't work. Instead of giving me correct bearing and distance. it would just show N 00d00'00" E 00.00' (this happens many times within one work session). Everytime it does that, i just go to Labels, Edit label setting, save and close. and i will work again for several minutes. Then I'd have to repeat it again.
Billy
