add new line in tool's Description
jagostinho74
Message 1 of 8
jagostinho74
Is there a way to add a new line to a tool's description when edited in the CUI Properties?
the "\n" is not working.
Thanks in advance
Assistant BIM/CAD Manager
Manchester, UK
Replies (7)
Message 2 of 8
pbejse
try "\r"
Message 3 of 8
jagostinho74
\r does not work either 😞
Manchester, UK
Message 4 of 8
hak_vz
Actually try  both \r\n since on Windows this is the standard line break  (CR LF)
Since lately Unicode is used you may try also to use:
U+000A
U+000D
or CR+LF: CR (U+000D) followed by LF (U+000A)
Miljenko Hatlak
Message 5 of 8
jagostinho74
None of them seem to work, @hak_vz . Or I might be typing them wrong in the Description field.
Manchester, UK
Message 6 of 8
ВeekeeCZ
At first - prove yourself that this is even possible - find ANY of the current tools that is using paragraphs in description.
If negative, just use multiple spaces "                                   " without quotes. The width of tooltips is fixed, so there should be no issue.
Seems to me that you're ghost hunting.
Message 7 of 8
jagostinho74
Very good point @ВeekeeCZ .
Manchester, UK
Message 8 of 8
pbejse
Another Workaround:
What I did is type the description in Excel using Alt+Enter for new line, copy the contents, paste it on the "Description", remove the leading and trailing quotation [ " ].
Result:
I'm sure someone from this forum will find the correct ascii or escape code for ALT+Enter, then everything will be fine and dandy.
