stricomp (from c/c++) function for autolisp
Moshe-A
Mentor Mentor
Moshe-A
Guys hi,
Did this last night, a function to compare 2 strings and ignore case but i wonder if there is a more efficient  way to do it  (maybe recursion)  any ideas will come in blessing?
the big numbers 6590 & 97122 return from (_case) have no meanig except for denote it is UPCASE\LOCASE
thanks
Moshe
; strings compare ignore case
(defun stricomp (s0 s1 / _case)
 (defun _case (n0)
  (cond
   ((and (>= n0 65) (<= n0 90))
    6590 	; upper case
   ((and (>= n0 97) (<= n0 122))
    97122	; lower case
  ); cond
 )_case
 (cond
  ((/= (strlen s0) (strlen s1))
   nil
  ((eq s0 s1)
   t
  ( t
   (vl-every
    '(lambda (n1 n2)
      (cond
       ((= (_case n1) (_case n2))
        (= n1 n2)
       ((= (_case n1) 6590)
        (= (+ n1 32) n2)
       ((= (_case n2) 6590)
        (= n1 (+ n2 32))
       ( t
        (= n1 n2)
      ); cond
     ); lambda
    (vl-string->list s0)
    (vl-string->list s1)
   ); vl-evrey
  ); case
 ); cond
); stricomp
pbejse
You mean without using strcase of course YES?
Here's the last bit
(defun stricomp_V (s1 s2)
  (vl-every '(lambda (a b)
	       (or (= a b) (= (+ a 32) b) (= a (+ 32 b)))
	    (vl-string->list s2)
_$ (STRICOMP_V "baNANa" "BAnaNA")
T
_$ (STRICOMP_V "banana" "banana")
T
T
_$ (STRICOMP_V "banana" "BANANA")
hak_vz
Or maybe this, if you have to compare nearly identical strings
(defun stricomp (s1 s2) (= (apply '+ (vl-string->list s1))(apply '+ (vl-string->list s2))))
Miljenko Hatlak
Moshe-A
@hak_vz ,
very good  😀 but not for all cases
(stricomp_v "a#$%" "A#$%12")
T
(stricomp "abc" "cba")
T
pbejse
"as the last bit" of your code <---  @Moshe-A
  (and
    (= (strlen s1) (strlen s2))
		) ;_ end of lambda
     ) ;_ end of vl-every
Moshe-A
that's beautiful @pbejse  - thank you very much
hak_vz
Or maybe this
(defun stricomp (s1 s2 case) (if (and case)  (= s1 s2)(= (strcase s1  T) (strcase s2 T))))
If case is important use (stricomp s1 s2  T) if not (stricomp s1 s2 nil)
Miljenko Hatlak
