zooming while using pline command
While I am in the pline command and zoom with the wheel, the pline goes away and I only see the starting "x".  Then when I complete the pline and exit the command, the pline shows up again.  Does anyone know why this may be happening?  It happens in Autocad 2015 and 2016.
imadHabash
I think that you should check your Hardware acceleration.
Option -> System tab
Imad Habash
I checked my hardware accelerater and it is turned on.  I turned it off and I still have same problem.  An other thoughts?
Is your pline width set to something other than 0 while you are drawing it? Because you can get some odd visuals when you are zoomed out in this scenario. If this is the case, try setting your pline width to 0 while drawing it and then change it after to your desired width.
pline width is set to 0.
