Zooming Model Space in Viewport cannot change centerpoint
Rudy.Reavis
Message 1 of 49
Rudy.Reavis
Please excuse the subject line.  I could not find a succinct description of my issue.  This issue just began this week.  I suspect I opened a third party DWG that changed a system variable.  I use the System Variable Monitor, but I did not receive any alerts.
Here's the problem.  I can unlock a viewport.  I can switch to model space.  When I try to zoom out from here, and zoom in over there, it doesn't work.
I can only zoom straight out, and then zoom straight back in.  If I hold down the CTRL or SHIFT key, I get the same result.  Straight out and straight back.  ???
Replies (48)
Message 2 of 49
imadHabash
Depending on your AutoCAD version ... would you confirm that you have installed the latest update?
Imad Habash
Message 3 of 49
RSomppi
Why do you suspect that? Files should not change system variables.
Message 4 of 49
Rudy.Reavis
I do not suspect it, I know for a fact that it happens.  Isn't that the whole point of the System Variable Monitor.
Message 5 of 49
Rudy.Reavis
Is there a way to determine what update I am running?
Like I said, I opened a third party DWG and now zooming model space through a viewport has chanted.
Message 6 of 49
Rudy.Reavis
These are the outstanding updates from Autodesk Access.
Message 7 of 49
imadHabash
type ABOUT command and take a screenshot for the dialog and attache it here please?
Imad Habash
Message 8 of 49
RSomppi
Does it do it for all files now? I suspect not.
Again, files shouldn't be changing system variables. That would not be a good thing for anyone receiving files from 3rd parties. I doubt that is what happened to you.
Share the file in question.
Message 9 of 49
Rudy.Reavis
Running AutoCAD 2025
Message 10 of 49
Rudy.Reavis
"Does it do it for all files now? I suspect not."
Yes, it happens with all files now.
I can "recenter" the ZOOM, by zooming out and then zooming to a window.
Now it is recentered to the new window.
System variables changing values happens frequently, especially PICKADD.
I like to set to 2, and it is frequently reset back to 0.
I get a notification when that happens, too.
Message 11 of 49
RSomppi
I suspect that you have a 3rd party program or a LISP running, if you have system variables changing.
Eliminate those and do a reset.
Message 12 of 49
imadHabash
You have the latest update.
I suggest to try working without the 3rd party program be activated. then see if any changes happened.
Imad Habash
Message 13 of 49
Rudy.Reavis
"I suspect that you have a 3rd party program or a LISP running, if you have system variables changing."
I do not know for a fact that I have had a System Variable change.  But, it is consistent wi9th the observed behavior.
If the third-party file had loaded a program, then it would unload when I closed the program.  In fact, I can shut down AutoCAD, turn off the computer, and come back the next day and still have the same problem.
The only type of change that I know of that can persist in that way is a System Variable.
Message 14 of 49
Rudy.Reavis
If the third-party file had loaded a program, then it would unload when I closed AutoCAD.  In fact, I can shut down AutoCAD, turn off the computer, and come back the next day and still have the same problem with a brand new file from a DWT file.
[EDIT] I used APPLOAD to see what was loaded, and if the Startup Suite had been modified or added to.  Negative on both counts.
Message 15 of 49
RSomppi
Once again, the file did not change a variable or load a program. That's not how it works. .dwg is a very secure file format. Forget about the file and focus on YOUR system.
Message 16 of 49
pendean
Community Legend
Community Legend
@Rudy.Reavis Since I can do what you are asking for in both AutoCAD 2025-26 in all of my and outside files without issue all day long, it may be time you consider posting a full program window video of your issue so we can all observe what you see and perhaps what you might not be seeing.
Do you know how to do that? It needs to be high-res.
Message 17 of 49
RSomppi
Trying some reverse engineering here and tried to find a way to make it zoom in and out at the center. It appears to not be possible. No system variable for it unless you are in a perspective view.
Message 18 of 49
J-Porter
What is your UCSFOLLOW set to?  It should be set to 0.  This is usually for an automatic zoom extents issue, but I'm shooting in the dark for a possible solution here.
Message 19 of 49
Rudy.Reavis
"Once again, the file did not change a variable or load a program. That's not how it works. .dwg is a very secure file format. Forget about the file and focus on YOUR system."
No offense, but Most system variables are stored in the DWG file.
As I pointed out earlier, that is whole point of the System Variable Monitor Window.  It lets you know when the drawing you just loaded changed a System Variable.  Unfortunately, it will only notify you about variables that you have configured for it to monitor for changes.
Please refer to the link below from Autodesk Technical Support.
System Variable Changed message appears in AutoCAD
Thanks, for the help, anyway.  Have a nice day.
@Rudy.Reavis - this post has been edited due to Community Rules & Etiquette violation
Message 20 of 49
RSomppi
@Rudy.Reavis wrote:
No offense,
Why is it when someone says "No offense" it is immediately followed by something offensive?
System variables are not file specific. That's why they are called "System Variables". Anything that is drawing specific is a drawing setting, not a system setting.
See?
@RSomppi - moderation edited quoted material.
