Zoom to Map Location with WMS Integration?
I am importing aerial imagery directly into AutoCAD 2015-2016 using a WMS connection (imagery is from NearMap). When opening a file that uses the WMS connection, I have to locate and zoom into my map location each time. Is there a way to set the map location and zoom level that the file opens to, or save the previous map location? Thanks!
stevetamplen
Hello jamesw, and welcome to the Forums!
I am not seeing that behavior in a standard insert of a Googlemap, in AutoCAD 2016 a simple save gives the new view with no problem.
Can you please upload a sample drawing that shows this behavior?
Steve Tamplen
Technical Support Specialist
Thank you for your response. You are correct - I can't recreate the problem we previously ran into and the map location is opening properly now. Thanks again.
