Friends, as it can be seen from the picture, although I applied the zoom extens command. The drawing is notting centered.
The commands I tried are; Purge, Audit, Dxfout. 😥
Solved by Kent1Cooper. Go to Solution.
Without your DWG, we can't check the content 😉
Try it yourself:
Command: _-LAYER _th * _on * _unl *
Command: _ZOOM _e _ZOOM 0.8x
Can you see the problem now?
If not: CTRL+A
And now?
If not, share your data..
Sebastian
It Zooms to the Extents just as one would expect, for me.
@SERDAR.CINAR59 wrote:
what should I do ???
Since it won't give me the problem in the same drawing, it doesn't seem to be a problem in the drawing itself. [Does it happen for you in all drawings?] I have nothing to suggest short of maybe resetting or reinstalling AutoCAD.
