AutoCAD Forum
找尋線上考過證照資料
7 REPLIES 7
Message 1 of 8
1312 Views, 7 Replies
找尋線上考過證照資料
我想請問 之前在Autodesk有考過3D MAX 跟CAD  要線上找考過的證照資料
但是現在換新系統,我沒辦法用舊的Autodesk帳號登入
所以找不到我先前考過的證照資料,我該如何找回資料,轉到新的系統
7 REPLIES 7
Message 2 of 8
imadHabash
HI,
the translation for this post is :
I would like to ask before the Autodesk has been tested in the 3D MAX and CAD to find the test evidence online
But now the new system, I can not use the old Autodesk account login
So I can not find the evidence of the previous exam, how can I retrieve the information, go to the new system
i wish anybody from AutoDESK can provide an answer for this question that how old users can get their certifictaes and logos?
@john.vellek
@Emmsleys
Imad Habash
Message 3 of 8
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am sorry that your old logon did not work. You might want to contact support through your Account page to see if they can help you reconcile this issue.
I suggest you go this page to find your regional contact about your Autodesk certification information.
John Vellek
Message 4 of 8
TheCADnoob
in reply to: john.vellek
I recently had an older certification pulled up.
If it was certified accreditation, i believe all of autodesk certificates are handled by certiport now: www.certiport.com/
You have to set up an account with certiport.
I had to have them retrieve my old certs using the numbers on my certification.
After that i just long into certiport and go to my transcripts.
The logos are handeled by Acclaim through certiport. :https://www.youracclaim.com/
Unfortuantely i could not get them to issue past badges for my older cert 😞
To get you current stuff go to Acclaim and log in. then go to your profile
There you can see your badges
click on share
then click on varios methods to share. To get the actual file you click the download icon.
CADnoob
Message 5 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 6 of 8
Secttor
Any ideea why won't show up under my avatar in topics? In my profile is visible sometimes..not always.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 7 of 8
TheCADnoob
in reply to: Secttor
Its odd, it was here when i first looked and then it disappeared. It looks like mine is doing the same thing.
I might bring that topic up in the community forum. It does seem to be kinda random.
https://forums.autodesk.com/t5/community-feedback/what-is-the-community-feedback-forum/td-p/5685889
CADnoob
Message 8 of 8
Secttor
in reply to: TheCADnoob
Indeed..so strange.
AutoCAD Inside the Factory
