Xrefs not showing up when i plot
Message 1 of 9
Hello, I'm having an issue with my Xrefs not showing up when I go to plot. The drawing shows up in paper space on my title block but when I plot nothing is showing up. Any help would be great.
Replies (8)
Message 2 of 9
Maybe a silly one but the layer that the xref is on is it set to plot?
Hope this helps!
Message 3 of 9
Hello, yes it looks like the layer is set to plot. Thanks for the advice if you have any other solutions I'd be happy to hear it.
Message 4 of 9
Just to check that the xref isn’t on a defpoints layer? Or created on this layer then xref’d?
The final option i have seen before is to run Recover on the dwg file (sometimes could be a glitch)
It is all I can think, I hope this helps!
Message 5 of 9
s.borello
What layer is your xref on?  Is it set to plot?  Try restarting your machine... same results?
Message 6 of 9
I checked the layer to make sure it wasn't on defpoints. I'll try running the recovery and see if that helps. Thanks again.
Message 7 of 9
Its set on layer 0. Just to make sure how do I double check to make sure its set to plot?? Maybe I'm looking at the wrong thing.
Message 8 of 9
I found one of my drawings was set on DEFPOINTS. I appreciate the help.
Thank you
Message 9 of 9
Did that solve your problem?
Many thanks!
